earnings show 2 extra workers then my miner stop earning
i looked at my earning page and noticed 2 extra workers that were not earning anything. then as i watch my worker(l3+) went offline. i looked at my antminer and the link was dead(under 1 min) but quickly came back on. Now my miner isnt earning anything and no hashrate is being clock for the last hour. I just started mining here today btw but had no issues at all with nicehash while testing on thier site
is this normal? will my earning come or have i lost an hour? do i reset my miner or is the problem on your end?
micca410evo
Re: earnings show 2 extra workers then my miner stop earning
Reset it to be sure on your side, if you are hesitating try another pool for the meantime
it started working a few minutes after posting this. i lost about 40 min of mining though. not that big of a deal but i have only been mining here for about 4 hours and 40 minutes of that wasnt earning anything. I plan on mining 3 day on this site to see that average before deciding. i really really like that you can get paid out in any coins and all the options they have here for sure.
already happened again....I reset miner and it worked for a few minutes then stopped...
last 10min not earning anything again as my miner is connected to a active pool so it hasnt switched to the backup
any suggestions on how to fix this?
post your username and password arguments
no password arguments
username: Jakeg5280
username: Jakeg5280
after reseting my miner it runs for about 15min then show 3 or 4 extra workers and i stop earning. if i leave it for another 20min it will work for a minute then more workers show up and i stop earning. connection shows as active on my miner so i have no idea whats going on. miner has been working fine on another pool
my firmware is the most up to date
hashingpro
add the password n=worker1
without a worker name the field is blank or has random characters that bleed over.
every so often the data its using as a name changes and causes a new miner with new info to appear.
setting the n=worker1 password will give it a static name to find and replace each time.
Welcome to mining.
Welcome to mining.
i would also add a=scrypt, its not required because its the default setting, but i like to make sure sometimes, if youre using an L3+, i recommend a static diff of 131072.
so in total:
n=[giveworkername] a=scrypt d=131072
EDIT:
also read this in case this applies to you
Change to authorization
so in total:
EDIT:
Last edited by GregoryGHarding on Sun Sep 24, 2017 3:07 am, edited 1 time in total.
thanks guys! will do.
ill give it a few hours and let you know how it works
