Hello, I have à problème today, I cant connect to prohashing with my Gminer v2.70 today
Its says « connect to eu.prohashing.com …. Failed : forbiden socket
All user mining pools are unavailable
Impossible to connect my Gminer
- Mastermind007
Re: Impossible to connect my Gminer
First is to check if you and antivirus getting in the way.
Second is to open a command prompt and see if you can ping eu.prohashing.com.
Lastly double check the gminer config. I use that version as well and have no problems connecting to the pool.
Something like:
[/b]
Good luck, hope you get it working.
Something like:
miner.exe --algo ethash --server eu.prohashing.com:3358 --user USERNAME --pass l=6,a=ethash,n=Rig01 --proto stratumGood luck, hope you get it working.
- Contact:
This may explain the issues you were having. If you are still having trouble, please submit a support ticket so we can help you look into it.Elevn06 wrote: Thu Oct 21, 2021 1:44 pm Hello, I have à problème today, I cant connect to prohashing with my Gminer v2.70 today
Reminder: Major system maintenence on October 21
