L3+ working ?
L3+ working ?
Just signed up today with Prohashing.com, started solo mining Litecoin with a L3+. I can't tell if its actually working correctly, in Antminer IP address under kernel log it shows alot of dump commands and some time errors. On Prohashing.com dashboard it say 1 active but not sure ?
Thanks.
Thanks.
Re: L3+ working ?
Also Antminer IP Address log shows:
ul 18 21:29:29 (none) local0.warn cgminer[2483]: Failed to resolve (?wrong URL) stratum+tcp://:(null)
Re: L3+ working ?
Could you post a screenshot of the miner's dashboard, on the page with the pool settings, so we can take a look?
Re: L3+ working ?
Are you talking about the Antminer, "Miner Configuration - General Setting" screen that show the URL,worker and password ?
Re: L3+ working ?
or miner status page ?
Re: L3+ working ?
That's the screen!wcoombe wrote: Sat Jul 18, 2020 9:18 pm Are you talking about the Antminer, "Miner Configuration - General Setting" screen that show the URL,worker and password ?
Re: L3+ working ?
url - stratum+tcp://prohashing.com:3333
worker - wcoombe
password - c=litecoin,n=Antminer1,m=solo,i=l3_504
worker - wcoombe
Re: L3+ working ?
Hi wcoombe,
I looked into this issue a little further, but I wasn't able to find anything obviously wrong with your configuration. Your account was created successfully and the parameters you entered appear to be correct.
I think the next step is for you to create a support ticket, so that we can obtain your IP address. Once you do, then Chris will be able to look at server logs to see what could be happening, given that you do seem to be receiving a response from the server and aren't having trouble connecting entirely.
Thanks,
-Steve
Thanks,
-Steve
