runaway reconnects on quark
see image, i only actually have two workers...
![Image]()
Re: runaway reconnects on quark
too many reconnects me thinks
if you disable merge (e=off), this may reduce the hash-still-play from previous mining instance
and that miner count should go down to only the actual quantity miners you have
Is this problem only present with Quark, or are other algorithms affected?
my z9 mini hasnt had the issue, so possibably only quarkSteve Sokolowski wrote:Is this problem only present with Quark, or are other algorithms affected?
seems to have corrected itself, after opening over 2000 connections
What exact time, down to the minute, did this issue occur, and for how long?
was actively occurring at time of posting, other than that i cant remember, took about 15-20 minutes to correct itselfSteve Sokolowski wrote:What exact time, down to the minute, did this issue occur, and for how long?
There is something that happens many morning at around 6:30am EST, and I don't know what it is. We'll have to keep looking to see if similar connectivity issues happen every day in the future.
