Can't solo Florincoin
SteinerMiner
I checked to make sure it wasn't in error and I even copied and pasted the spelling into my miner configuration but it still comes up as dead. I have c=florincoin m=solo what's going on?
SteinerMiner
Re: Can't solo Florincoin
I guess no one cares that a coin isn't in error and it still cannot be solo mined. Really builds my faith in this company...
what miner are you using?
Can you take a screenshot of the config page with the mining info, blank out the username if you need to.
SteinerMiner
2 l3+ and 1 l3++
I also tried connecting to the proxy link in case that was it but to no avail.
Below is the link to the image.
https://ibb.co/fpSB6d
So first check would be, remove the pool2 info and remove the password of pool1. See if its able to connect without any password using that info.
I would also suggest trying to reverse the order, set m=solo c=florincoin and give that a try, assuming without any password it connects and works that way first.
