Would like to know if I could point a script miner to sha- or the other way, can I solo mine a script with sha miner.?
Thank you
Solo mining sha vs script
MEXX8n3YTDa9XHR92mCp9yKUkexswQ7J83
Re: Solo mining sha vs script
No.
If its a graphics card system they can be made to mine multi algos based on what program you use.
Like a computer, you can load multi operating systems up on it.
ASIC machines are printed circuits that can't change, they run very fast in 1 specific way and thats it.
If another algo is close sometimes they can cover another, but usually, scrypt is scrypt and SHA is SHA
Ya, CSziggy thats what I thought.
Thank you
Thank you
All you need to do is specify
a=sha-256 c=[Explorer COIN besides BitCoin] m=solo
Make sure you use the precise Explorer parameter for the coin - it is usually not the abbreviation...
You need to set up a wallet address for your earnings as these will not be converted into your payout coins specified.
And of course, you may need to register to trade for other coins / fiat. Prohashing mentioned they are adding HitBTC so that might be your best 1st option if you aren't already an active trader/want to be paid in cons not support by Coinbase.
