- The website will be updated to include documentation and text changes about SHA-256 mining.
- The coin servers will be updated to queue blocks when a disconnection from WAMP occurs, which will reduce the number of orphaned blocks and increase profitability during periods of poor connectivity.
- The mining servers will be restarted to resolve an issue with some equihash mining software that incorrectly assumes that the server is non-responsive after 12 minutes of not sending a new block.
Releases tonight
Releases tonight
We'll be issuing several releases tonight, which will affect different areas of the system.
Re: Releases tonight
took a look into the equihash client assuming the work is stale, apparently there is no option to remove or change the timeout threshold. what are you changing server-side? re-issuing same work after 10 mins?
