i just bought some oldschool mining hardware and hoped i could use it here, i am a new miner.
its currently clocked to 11 mhash, what i want to know is if i can set my own difficulty like explained on site ? d=2048 example ?.
or what is your lowest difficulty ?.
i am using cgminer 3.1.1 for windows with zeus support.
thanks for help in advance.
regarding lketc miner
mistereudk
Re: regarding lketc miner
you can set a static difficulty as low as 16384. if your miner can find shares at 65536 starting difficulty on dynamic difficulty then leave it on dynamic and it can go down to 8192.
i didn't know lketc miners would work with zeus software. i own a couple zeus miners and use a different version of bfgminer.
i found this version of cgminer on github for lketc miners if that older cgminer doesn't work for you
https://github.com/wareck/cgminer-lketc/releases
mistereudk
if i want to mine gamecredits an then set difficulty to to 16384 how do i do that ?
