Hello,
It's stated in your documents that is you want to mine a certain coin, you have to type the m parameter lower case exactly as the coin list in the home page. Where is the list on the home page?
Also, how do you find the coin code? The Dnote coin, what is the code of it? There is also a coin called Dnotes (NOTE), but I guess that is not the same. Pretty confusing...
How about in the settings when adding a new coin, you can state the coin code in the text box of the wallet address.
Thanks!
Coin list and codes
Re: Coin list and codes
https://prohashing.com/explorer
go there, choose your coin, hit SELECT and on the left side look for "how to mine"
