What happens if PH is crashing? Or the live worker status is going back to "Time first share=0:00" My miner had no break!
Is the miner now starting to calculate a new block and takes many hours again or is miner continuing correct work?
My solo mining is often breaking after some hours, is this the distance to pool or how can I avoid it?
My miners are configured correct with m= solo and c=Coin, do I need more values?
What URL do I have to use ping xxx.xxx.xxx.xxx??
Thank you
