If any of you look at the daily profit report you'll know what im talking about,So ive done a little test on a few coins over the past 2-3 days to see if i can make their autoswitcher flood a coin with hashrate causing there wallet/daemon not be able to keep up with the found blocks........this causes it not to send work restart's in a timly manner making miners to contine to do the same set of work units resulting in a orphan when a block is found again.
example::
Bunnycoin
-not even included in the 28.12.2017 profit report even tho i mined and received it
27.12.2017 daily report info - here you can see they expected a very high orphan rate,even tho it was much lower (because i spent a good part of the day solo mining it stabilsing the hashrate for the wallet/daemon)
and heres what happening when the wallet/daemon is getting swarmed, prohashing is focusing its workers to the coin (this is from the live blocks found on the homepage)
and heres the result im seeing for my local worker with my personal blocks found
Your Server cant handle it?
Your swamping your own coins?
Your causing your own orphans?
Your wasting hashing power?
The temporary fix's of fixing difficulty at no lower than 65k are rubbish
To big to quick,to many shares,to many miners,what happened to the 2015 days
so steve or chris, what do you have to say about this?
