A Supply of 150,000 + 1 BIX total 150,001 BIX has been Mined by Us.
See Below for more details.
10 Blocks of 15,000 BIX
Block 1 -> a96e8de66e3c4c31793d6715c45ce88f19f0d1f9079b5bc50f843d33c82071b3
Block 2 -> eabba2e71ab92f443a7977341e71c94a7733f52afb23b77ec4c1435e902b36f3
Block 3 -> 6fdd68207ab8d432323965fa09b645bf7d5088764f03307df00cc61f99f1e739
Block 4 -> c44ae4f84ff8c70c47156763e156a6b6d850012df2e3a22acbba9b53059e982e
Block 5 -> 2b2fa53397a83ce3ae8e7ec79ff9e96e9f62f6b5e5b5b69ed87d460a82dda8ca
Block 6 -> 5569b649393709eb1bd1339b74d486a6d7b0589233f92d711cb9d79de48f0cc8
Block 7 -> b2409285aeee6d353f9465ed5e40ef8bd0051eb3401f08bae6c9843c01f61676
Block 8 -> 42f4094ab12853c9baa1aeff38f5631844f52566e82f2bf9cb7019d9f4ddab54
Block 9 -> be1f937ae6dfe2784bf312b5bcb155f49d4be645709462bbbff5a1d99ddfb515
Block 10 -> 9a339b1ec3367dd911d944fecfe6aaec5793cb8a5a3a54f0ff76be3a8bd06f59
1 Block of 1 BIX
Block 11 -> 517790d298d6fbe95eaedaa05b5afe653391056bd3b1063842fd427b14cc9006
Breakdown:
150,000 BIX = for sale @ 0.00008btc Per 1 BIX (This is so we can pay for our own server Infrastucture to maintain Website's, Web Wallet which includes staking capabilities, Masternodes, Block explorers, Faucets and downloadable media for the BIX network Along with outsourcing Engineer's.
1 BIX = for the transaction fee so all 150,000 are sent to be sold instead of 150,000 Minus 0.0001 per kb in tx size.
The BIX will not be staked. This will only happen once people whom have aquired BIX have withdrawn to their wallet and Matured their BIX for Staking.
It will Last 7 days or until all BIX are gone which ever is sooner.
If all BIX Coin do not get sold then the remaining proportion will be Burnt Publicly to keep all fair.
The Proceeds are made out for what is written out in the structure below.
PoW is enabled with a 0 reward only to move blocks forward until People have aquired enough BIX to stake once done PoW is not needed and will fully stop. I'll implement a block to which PoW stops once PoS is moving Firmly by itself.
SALE LOCATION
Name = BixCoin
Abrev = BIX
Type = Pure PoS
Max Supply = 42 Million BIX
Max Orphan Blocks = 625 Blocks
Max Block Size = 85 MegaByte
Dump Address Interval = 5 Minutes
Max Outbound Connctions = 42 Connections
Proof Of Stake Block Time = 90 second blocks
Proof Of Stake Target Timespan = 15 minutes
Proof Of Stake Coinbase Maturity = 80 blocks
Proof Of Stake Modifier Interval = 15 minutes
Minimum Stake Age = 1 hour
Maximum Stake Age = 14 days
Proof Of Stake Coin Day Weight = 24 hours
Proof Of Stake Combine Threshold = 15,000 Coins
Proof Of Stake Split Threshold = 30,000 Coins
Block 0 - 150 = 52.78% Per Annual year
Block 151 - 15,000 = 527.8% Per Annual Year
Block 15,001 - 30,000 = 263.9% Per Annual Year
block 30,001 - 45,000 = 131.95% Per Annual Year
block 45,001 - 60,000 = 65.97% Per Annual Year
Block 60,001 - Onwards = 57.28% Per Annual year
Transaction Fee = 0.0001 Per Kb
Transaction Confimations = 2 Blocks
Port = 11628
Testnet = 21628
Rpc Port = 11629
Testnet = 21629
Instantx Signatures = 12 Blocks
Instantx Signatures Max = 24 Blocks
Darksend Collateral = 1,000 BIX
Darksend Fee = 0.0001 BIX
Darksend Pool Max = 999,999.99 BIX
Masternode Min Confirmations = 12 Blocks
Masternode Reward = 30 Per Blocks
Masternodes are due to start on Friday, 15 December 2017 12:00:00AM that should
ensure that enough coins are circulated and we have gained ground first.
We would say the easiest way for this is if you use coin control to put that amount into one and
send it yourself and/or use an exchange to withdraw that amount to your address ie send 1,000
coins exactly to your masternode wallet.
Select the Masternode tab from the left hand side menu
Then select My Master Nodes
Then press create
Insert your alias name as requested
insert your ip address along with the port as requested ie 123.456.789.000:9999
Then press ok
You should now see a masternode on the list in front of you
copy the address to notepad or your preffered txt editor
Now press Get Config
copy/paste the Masternode Priv Key & your address and paste them into the masternode.conf below
send exactly 1,000 coins with the standard tx fee nothing more nothing less to the masternode address you copied
wait for it to confirm in the blockchain Now make sure you have opened your port in Firewall / router if you have one
Running Masternodes
Way 1
Goto Masternode Tabs on the left hand menu
And press start
Way 2
Goto console in the debug window
Type -> masternode start
If you have an Encrypted wallet
Type -> masternode start YOURPASSWORDHERE
To see the status of your masternode
Type -> masternode list
masternode.conf
maxconnections=100
rpcuser=YOURUSERNAMEHERE
rpcpassword=YOURPASSWORDHERE
rpcport=11269
gen=0
staking=0
listen=0
server=1
daemon=1
port=YOURPORTHERE
reservebalance=9999999
logtimestamps=1
masternodeaddr=YOURIP:YOURPORT
masternode=1
masternodeprivkey=YOURPRIVATEKEY
The Block explorer does not report 0 block reward blocks. This can be adjusted if needed
[url=http://]
[/url]
