Why Set Diff?
Why Set Diff?
If the system will set optimal diff, why bother setting it? Seems counter intuitive to me....
hashingpro
Re: Why Set Diff?
Does it?
Set the optimal difficulty?
Re: Why Set Diff?
The ph notes say it does. it says if you leave it blank, it sets it optimally.
micca410evo
Re: Why Set Diff?
3Moose wrote:The ph notes say it does. it says if you leave it blank, it sets it optimally.
For the side of PH, since they don't want you to submit to much shares, some machines require more or less shares than the other. That your enemies tactics are optimal doesn't mean that your team is good at it. (because someone said there is a 75% chance at ethereum being crypto leader, doesn't mean it will)
