PROBLEM between Nicehash and Prohasing
thoithien1993
Hi everyone, I bought hashrate about 2GH for X11 at Nicehash, but I saw only hashrate about 886 MH at Prohashing. this make me lost money.
. At Nicehash, I set password : a=x11 g=off d=2 h=1000. Could you explain ? Thank you
Re: PROBLEM between Nicehash and Prohasing
Those are the settings that have worked for me in the past.
Did you look at the performance graph while it was running?
If you start it again and there is still this problem, could you generate a .png or .jpg of it so we can see if it's stales, rejects, delta or what
thoithien1993
You can see it here: http://imgur.com/a/uCGFz
Could you suggest me a new setting password at Nice Hash ?
Are you sure it uploaded ok?
I see other images on the site if I click around a bit, but there doesnt appear to be anything there on this link. (for me at least
thoithien1993
ohh, Sorry bro. It may be wrong from me. I tried uploadi again here, you can see: http://www.upsieutoc.com/image/IOnOmq
and http://www.upsieutoc.com/image/IOnrum
mickeekung
I recommend that you should avoild for order X11 at Nicehash right now. Even if the recommended setting, I still get bad profit and high negative delta/reject too. Suggestion to order Scrypt instead of X11.
thoithien1993
Ya, I think so. Could you suggest me the recommended password for scrypt ?mickeekung wrote:I recommend that you should avoild for order X11 at Nicehash right now. Even if the recommended setting, I still get bad profit and high negative delta/reject too. Suggestion to order Scrypt instead of X11.
mickeekung
d=8192 g=off h=1000thoithien1993 wrote:Ya, I think so. Could you suggest me the recommended password for scrypt ?mickeekung wrote:I recommend that you should avoild for order X11 at Nicehash right now. Even if the recommended setting, I still get bad profit and high negative delta/reject too. Suggestion to order Scrypt instead of X11.
thoithien1993
Thank you so much !mickeekung wrote:d=8192 g=off h=1000thoithien1993 wrote:Ya, I think so. Could you suggest me the recommended password for scrypt ?mickeekung wrote:I recommend that you should avoild for order X11 at Nicehash right now. Even if the recommended setting, I still get bad profit and high negative delta/reject too. Suggestion to order Scrypt instead of X11.
Xfighter87
Hallo. Ich hab das Problem das meine Buyorder bei Nicehash immer automatisch beendet wird ohne das er anfängt zu arbeiten. kann mir einer sagen woran es liegt, was ich falsch mache?
LG
Daniel
https://picload.org/view/rpwrrggw/screenshot_1.png.html
Hello. I have the problem that my buyorder at Nicehash is always automatically terminated without it starts to work. Can someone tell me what is wrong, what I am doing?
greetings
Daniel
LG
Daniel
greetings
Daniel
