- Dramatic improvement in mining server startup time from 15m to 30s, so that future restarts will result in less downtime
- Reduction in memory usage to support 3% more miners
- Reduced mining server CPU usage to support 2% more miners
- 2-factor authentication
- Fixes for broken charts on the charts page
- Improvements to documentation and payout thresholds to reduce customer service inquiries
- New f_all_balance_updates WAMP function to get initial miner balances
- Addition of 64GB swap space to mining server to queue 4x as many shares in the case of a long-running database operation
- WAMP API now includes timestamps to assist subscribers when database is behind
- Implemented the WAMP API changes on the website to produce a live clock of how far behind the system is
Release coming on Wednesday
This is a heads up about a release that is coming on Wednesday, probably in the afternoon. There will be 10 minutes of mining downtime, but the website might be down a bit longer if we have problems during deployment. Here are the features in the release:
Re: Release coming on Wednesday
My advice on the swap use SSD's in a raid-1, they will be fast enough (faster than a disk for sure) and since the extra swap load will put abnormal stress on them you are protected against a predictable wearing failure in a part.
if its 64 gb of devoted hdd i could only assume its an SSD unless its virtually allocated space on a harddrive
