Immature Blocks not credited yet?
CyberBeast135
Post by CyberBeast135 » Sun Jun 23, 2019 2:29 pm
I am mining BitcoinV and the block explorer show the blocks are confirmed.
ProHashing is still showing immature after hours?
Why is this happening?
Re: Immature Blocks not credited yet?
Post by Steve Sokolowski » Sun Jun 23, 2019 2:50 pm
CyberBeast135 wrote:I am mining BitcoinV and the block explorer show the blocks are confirmed.
Most coins take a long time to mature. For bitcoin, for example, the maturity time is 100 blocks, which is about one day. Some coins can take as long as four days.
The other reason that coins can take a long time to mature is because nobody is mining that blockchain. To figure out whether that is the case, compare the height of the latest block from the block explorer with the height of the block you are waiting for maturity of. If nobody is mining the blockchain, then the chain won't advance, and your blocks won't be confirmed.
CyberBeast135
Post by CyberBeast135 » Sun Jun 23, 2019 2:56 pm
Thanks Steve, I will check the explorer and give it some more time.
CyberBeast135
Post by CyberBeast135 » Sun Jun 23, 2019 6:52 pm
Steve,
I went to the oldest block in the list and it now shows 78 confirmations.
Unfortunately, it has not been credited yet?
Summary
Previous Block
000000000000019ae30f5511145434f148e49c8b737840124b6eb9c4462b1d86
(#11,151)
Timestamp
2019-06-23 16:18:54 utc
Transactions
1
Total Fees
0
Weight
1,216 wu
(0.03% full)
Size
331 bytes
Confirmations
78
Next Block
000000000000338c9ede00fa632164d7b1f250a06ea336fdb58690374d4b1b68
(#11,153)
Difficulty
307.311 x 103
Version
0x3fffe000 (decimal: 1073733632)
Nonce
395462954
Bits
1a3697c0
Merkle Root
8e39d1be2b34fd8bf013e0fea845e3664a934a65a8bf142f0eb2502ea1d0c15e
Chainwork
184.36 x 1018 hashes (9fe78aaceea8c8d79)
Miner
+½¦]ú¾mmҚ'kX0Š9FØý›ý® Þ±EhŠ>HðSåÊwý ½ðn/prohashing.comtˆ/
CyberBeast135
Post by CyberBeast135 » Sun Jun 23, 2019 9:02 pm
Steve, The blocks are starting to be credited now. Thanks for your help.
Post by Steve Sokolowski » Mon Jun 24, 2019 9:39 am
CyberBeast135 wrote:Steve, The blocks are starting to be credited now. Thanks for your help.
That's great to hear.
78 confirmations, for most coins, is not enough. The typical coin requires about 200, while some coins with long block times can require only 100. I'm not aware of any coins that require fewer confirmations than 100.
