This does not need to work.... anyone know why?
Pool: prohashing.com
Port: 3333
Username: ABC1
Password: x --scan-time=1 --queue=0 --expiry=1
Nicehash Friends
Re: Nicehash Friends
Have also tried:
Port: 3333
Username: ABC1
Password: d=65536 g=off h=1000
Port: 3333
Username: ABC1
What are the G and H options? Googlin around i dont see them...
I am confused on what are you trying to do moose...
If you have ASICs, like D3 ..... prohashing.com:3333, your username, and "a=x11 g=off h=1000" in the password field should get you started right away.
If you are pointing your D3 to Nicehash instead.... then "x --scan-time=1 --queue=0 --expiry=1" in the password field should be OK too.
or maybe.... Are you renting NH service to mine at PH?
Yes he is trying to use NH to mine on Prohash and cannot get the machines from NH to connect in and needs help.
Hi Guys,
Yes, I am just trying to figure out how NH works for scrypt mining.
When I fill in the parameters:
Port: 3333
Username: ABC1
it disconnects saying "difficulty to low". But keep in mind, I can set d=200000 at it will say that.... so its not "d" inherently.
Port: 3333
Username: ABC1
There are really no NH users on this forum all of a sudden??
have you tried just "g=off h=1000" or "g=off"
for difficulty just omit it and let the stratum servers handle it
i used to use a=scrypt h=1000 d=131072 g=off on NH but i`m not sure if this is still correct.
Be carefull, if PH has a problem, so do you...you will lose money, one way or the other.
(almost) daily problems on PH made me stop (it costs me to much time and money) but you can surely give it a try!
Pool host: prohashing.com
Pool port: 3333
Pool user: 3Moose
Pool pass: d=131072 n=nh
Algorithm: Scrypt
Resolving pool host prohashing.com... OK
Establishing connection with proxy... OK
Establishing connection with pool 167.88.15.87:3333... OK
Sending mining.subscribe... OK
Sending mining.authorize... OK
Received mining.notify subscription... OK
Received mining.set_difficulty... Pool difficulty too low (provided=65536, minimum=131072) ** ERROR ***
Waiting for pool to send higher difficulty.
Received mining.notify work... OK
Received authorization result... OK
Received mining.set_difficulty... OK: difficulty=131072
Pool port: 3333
Pool user: 3Moose
Algorithm: Scrypt
