Mining Rig Rentals can't connect
dysan819
Re: Mining Rig Rentals can't connect
Post by dysan819 » Thu Oct 09, 2014 4:29 pm
I have asked the rig operator what app and version he is using. I will let you know if and when they respond.
Post by Steve Sokolowski » Thu Oct 09, 2014 4:37 pm
Chris thinks that there's a way that we can reduce the number of work switches at the expense of a small amount of profitability, which might actually increase profitability for everyone because of fewer rejected shares. He's testing this now and it shouldn't take long to release once he gets it working. We can see if that might be the cause of the problem.
I'll add that diff=512 issue to the (long) list of feature requests. Believe it or not, there were four customers who contacted Chris last night and asked for multiple worker per account support, so because there are more requests, I think that probably has to come first.
dysan819
Post by dysan819 » Thu Oct 09, 2014 5:20 pm
Well if we're taking a vote, I say password settable difficulty, then multiple workers!
InsertNameHere1
Post by InsertNameHere1 » Thu Oct 09, 2014 5:32 pm
i had no problems with miningrigrentals. but mind you this is a beta site. you go super big into you can fuck everything up
dysan819
Post by dysan819 » Thu Oct 09, 2014 6:41 pm
I have a friend failing to connect with his GAW Fury miners using original bfgminer. Is that application known to not be compatible?
cryptorific
Post by cryptorific » Thu Oct 09, 2014 6:49 pm
No idea, up until now, we've only had zeusminer's and A2's, both of which use cgminer.
Site Admin
Post by Chris Sokolowski » Thu Oct 09, 2014 7:10 pm
I believe we have fixed the connection issue, as that was related to the database issue. Please try to connect again.
dysan819
Post by dysan819 » Thu Oct 09, 2014 7:46 pm
I believe you fixed the connection issue AND the reject issue! Great job!
dysan819
Post by dysan819 » Thu Oct 09, 2014 11:10 pm
Connection is still stable, but reject rate is rising.
cryptorific
Post by cryptorific » Fri Oct 10, 2014 12:22 am
Whats your efficiency at? I'd say anything above 98% is within a normal range, I have an A2 and a zeusminer x6, and the zeus consistently gets a bit lower efficiency (98-99%) than the A2 (99.5%) but there will be times I get a 100% efficiency and others that it dips to 98% . During the database issues earlier today it was as low as 70% with a lowering in the overall hashrate. If it starts looking like its a repeat let please post.
