Algorythm Parent coins are showing 0 profitability
Post by GregoryGHarding » Wed Dec 05, 2018 10:49 am
Expected Payouts for each algorithms parent coin is now showing 0, i understand quark because quarkcoin currently does not have a supported exchange for prohashing, i expect the others are an uncaught error?
alim
Re: Algorythm Parent coins are showing 0 profitability
Post by alim » Wed Dec 05, 2018 1:52 pm
Thanks for raising this - I noticed the same thing and wondered if I should say something. I have faith that the optimisation in place means that the "parent" coin will be mined if it is the most profitable (or near the top)....
Post by Steve Sokolowski » Wed Dec 05, 2018 3:21 pm
GregoryGHarding wrote:Expected Payouts for each algorithms parent coin is now showing 0, i understand quark because quarkcoin currently does not have a supported exchange for prohashing, i expect the others are an uncaught error?
This is a strange error. I'll ask Chris to investigate it.
