It seems some of the Prohasing.com Srcypt coins are (or near) defunct status, and the list is awefully small for an effective "what's most profitable to mine". In fact, my own calculations show that LTC (what shows up often as most profitable here) is actually 26/50 on the list I maintain. Here are some suggestions:
NLG
NVC
GAME
XVG-Scrypt
FLO
LTC
DGB-Scrypt
EMC2
NOTE
AUR-Scrypt
BTA
XSH
ABY
CAT
Browse some other pools, like Multipool.us, TheCoin.pw, and Miningpoolhub.com.
Thanks for your time and attention. (Just doing my part to help make this pool better. I really like the idea of it, but it must have more diversity across the network to be effectively competative.)
Cheers!
						Suggestions to add for Scrypt coins
- dragonbyte_llc
Re: Suggestions to add for Scrypt coins
Did you even view all the coins available on prohashing?
						- dragonbyte_llc
Oops. Yes, I found them all. Thanks.
