How to set up the Antminer D3
Hi everyone,
I expect to have my Antminer D3 in about a month or so.
And I had 2 question, first is what password I need to put?
I know I need to put : a=x11
Is there any other?
And the second question is how do the pool know how did the work?
I know it something about the name, but didn't understand it how to set up?
Thanks everyone
Is there any other?
Thanks everyone
				hashingpro
Re: How to set up the Antminer D3
under the miner configuration, you put in the:
pool address
username for your account
password.
						pool address
password.
do you have any prior knowledge of mining before ordering a miner?ZracheSs wrote:Hi everyone,
Is there any other?
Thanks everyone
Ok, so in my situation...
It will be like this :
prohashing.com:3333
ZracheSs
a=x11
That's it or is it more password.
I just want to be ready so I can start as soon as the D3 is here hihi
prohashing.com:3333
ZracheSs
a=x11
For gregory
No, not really... Got to start somewhere tho
I read alot, but no experience
just gauging how i need to wirte.ZracheSs wrote:For gregory
your pool will be prohashing.com:3333
Username: your ph username
Password: n=[w/e name you want(no spaces)] a=x11
using a n= name on your miner helps you track your performance charts in your account earnings page, otherwise ph will assign a random alphanumeric string as a name every time it connects. if you want to add additional password arguments like static difficulty you can review all password arguments @ https://prohashing.com/help.html
I took those info and I'll be back if any things goes wrong.
Thanks to both of you!
do you guys have any specific settings for  D= ????
yeah, same question...ajmax2018 wrote:do you guys have any specific settings for D= ????
and other question:
does anybody overclocks those D3's?
its just amazing how hot they are running... my L3+ miners are running in the same interior (16 degrees) by 55 degrees (overclocked) and D3's have without overclocking 75 degrees...
I think the D3s are shipped OVERCLOCKED.
If you go to the frequency advanced page, the D3s do not list a frequency, they list DEFAULT SETTING.
I think each batch they have sent out, has that DEFAULT = to a higher and higher clock, so it is already overclocked and anymore would probably be bad for the heat on them. Someone else said they had gotten in 3 different batches and each additional batch was pulling more and more wattage and they do have different frequencies on the status page across the batches even though each had DEFAULT SETTINGS selected.
