Recommended Settings for L3/L3+?
Longsnowsm
Post by Longsnowsm » Mon Jun 26, 2017 7:45 pm
What are the recommended settings for using the Bitmain L3 and L3+? Thanks.
n00bminer
Re: Recommended Settings for L3/L3+?
Post by n00bminer » Mon Jun 26, 2017 8:44 pm
I rent them on mining rig rentals. I use d=8192 n=machinename
frphm
Post by frphm » Mon Jun 26, 2017 9:16 pm
There was a user on here I talked to before I ordered a bunch of L3+'s, and he said he solo mines Litecoin, and gets 1.5 LTC per day per rig.
Longsnowsm
Post by Longsnowsm » Mon Jun 26, 2017 9:24 pm
n00bminer wrote:I rent them on mining rig rentals. I use d=8192 n=machinename
Thanks I will give that a try. :D
Longsnowsm
frphm wrote:There was a user on here I talked to before I ordered a bunch of L3+'s, and he said he solo mines Litecoin, and gets 1.5 LTC per day per rig.
LOL, That requires luck which I have NONE! ROFL
n00bminer
Post by n00bminer » Tue Jun 27, 2017 1:54 pm
I think maybe he meant, he c=litecoin but mines in PPS mode
vhmanu
Post by vhmanu » Wed Jun 28, 2017 9:45 am
my L3+ diff is 15000. Works like a charm.
n00bminer
Post by n00bminer » Thu Jun 29, 2017 9:29 pm
you ever try a multiple of 256 near that number like 14848 or 15104?
