Chris restarting mining servers
Post by Steve Sokolowski » Wed Jun 12, 2019 12:27 pm
Chris is going to restart the mining servers. The purpose of this restart is to change the way that Ethereum shares are processed, in an attempt to determine why luck seems to be poor for ETH blocks.
The restarts will only take mining offline for about 30 seconds.
djliss
Re: Chris restarting mining servers
Post by djliss » Wed Jun 12, 2019 12:57 pm
equ 144_5 is fucked again
Post by Steve Sokolowski » Wed Jun 12, 2019 1:25 pm
djliss wrote:equ 144_5 is ****** again
Could you provide more information? What error message are you seeing? Is there a particular coin that has a problem? What is your username so we can investigate?
djliss
Post by djliss » Wed Jun 12, 2019 6:18 pm
it was around 6pm uk time, username djliss , BTG was in error so i swapped to zel, that was giving me the end of file error, so tried btz and got the same error, tried again 5 mins later and seemed to be working again, seems as though when one 144 coin goes into error it throws the whole system for a while
