Prohashing with Non-ASICs?
premoguy
Post by premoguy » Wed Nov 07, 2018 6:08 pm
Forgive me if the answer is obvious, I have searched the forums and help pages for answers and came up with nothing.
Is there a way to use prohashing with windows miners like AIOMiner or PhoenixMiner? Setting it up, it looks like it should work. When I go to connect I can ping the destination fine but I'm stuck at "Waiting for job" messages nonstop and nothing ever pops up on my Earnings page. Is there a way to do this?
Re: Prohashing with Non-ASICs?
Post by Steve Sokolowski » Wed Nov 07, 2018 7:15 pm
premoguy wrote:Forgive me if the answer is obvious, I have searched the forums and help pages for answers and came up with nothing.
Which algorithm are you trying to mine?
Post by GregoryGHarding » Wed Nov 07, 2018 9:41 pm
take a few minutes and review the help page, and familiarize yourself with how prohashing handles logging in miners, they operate completely different to traditional mining pools. focus your reading on password arguments, as this is the most important part of connecting and hashing properly for you to receive an income.
https://prohashing.com/help.html
premoguy
Post by premoguy » Thu Nov 08, 2018 6:21 pm
I'm using Ethash, but I'd be open to using a different algorithm if one is more suited to GPU mining and prohashing
Post by GregoryGHarding » Thu Nov 08, 2018 6:36 pm
premoguy wrote:I'm using Ethash, but I'd be open to using a different algorithm if one is more suited to GPU mining and prohashing
ethash or cryptonightv8 are the most profitable options for gpu
Post by Steve Sokolowski » Thu Nov 08, 2018 6:48 pm
I'm not familiar with these miners. However, the Claymore ETH miner has been tested to work with ethash, if that's the algorithm you choose to mine. Have you tried that program?
keksik
Post by keksik » Fri Nov 09, 2018 8:20 am
for Ethash im using claymore and for CN V8 SRBminer, xmrstack works good too.
