Manual Payout Limit
dustind900
Manual Payout Limit
It seems (to me) that payouts are too small. I recently got a payout of .8 ETC. That amount is rather small for a payout. I would rather set the limit myself to 1 ETC or higher. Would it be possible in the future for you guys to add a feature where the user can manually set the payout threshold for a given coin?
Thank you,
Dustin
Thank you,
Dustin
- Chris Sokolowski
- Site Admin
Re: Manual Payout Limit
Hi Dustin. The reason for the payout threshold is pool security. We don't want to be a bank and hold large balances for customers making us a bigger target for hackers. If we implement this feature, we would definitely have a maximum setting for the payout threshold. I will talk with Steve about this so that I can get his opinion on whether this feature presents a significant security risk to us.
dustind900
A max setting would be wise. Thank you for your response
yup , plus some of the payouts are to low you can't post them on exchange much less sell because of how low the payout is.
eth should be set to -.1 eth and not 0.08 something even after it cashes out, no exchange will post it or even let you sell, it if it does post it, unless it's @ .1 eth not one dollar, i mean 0.1000000. I guess the Plus side would be send it to a coin based account, sense coin base sell/buys it now like Btc. or save it.
- Chris Sokolowski
- Site Admin
I just changed the minimum ETH and ETC payout to 0.1 for that reason. Setting the minimum payout per user will require changes to the website, and I have to fix some other bugs before I can get to it.
We already have a method that I can change to set a minimum payout per coin for all users. Does anyone have a suggestion of how I could determine the appropriate minimum payouts per coin for the entire pool? For most coins, we have it set to 0.0000001 because we don't have any better information.
- CritterDog
Personally I have no problem with the payout threshold certainly not a priority..But I was wondering if you can change the payout cut off time of reaching the threshold from 7pm central to 10 or 11pm central which is currently the start of next day pay cycle? As of now you dont get paid unless you reach that threshold by 7pm central timeChris Sokolowski wrote:I just changed the minimum ETH and ETC payout to 0.1 for that reason. Setting the minimum payout per user will require changes to the website, and I have to fix some other bugs before I can get to it.
- Chris Sokolowski
- Site Admin
For the purposes of payout thresholds, days begin and end at 12AM Eastern (11PM Central). If the system is working properly, the cutoff shouldn't be as early as you say you are experiencing. What coin(s) are you using that seem to be having an early cutoff? The only normal cause would be a drop in price; anything else would be a bug. 7PM central (12AM UTC) would make sense if the system was ignoring time zones, but I want to verify it's a problem first.
- CritterDog
What I am noticing is at 7pm central no matter what coin I mine the system takes a look at my account to see if I made the threshold. If I did I get the black checkmark which I assume is there to let me know that coin will pay. But I guess what I am asking is if we do have until 11pm why would the system even care or even look at what the balance was at 7pm central. Thanks!Chris Sokolowski wrote:For the purposes of payout thresholds, days begin and end at 12AM Eastern (11PM Central). If the system is working properly, the cutoff shouldn't be as early as you say you are experiencing. What coin(s) are you using that seem to be having an early cutoff? The only normal cause would be a drop in price; anything else would be a bug. 7PM central (12AM UTC) would make sense if the system was ignoring time zones, but I want to verify it's a problem first.
- Chris Sokolowski
- Site Admin
That check mark is generated by the website and doesn't actually mean that the payout is "locked in". Every time you load the page, the website compares your balance to the threshold and shows the check if the balance exceeds the threshold. For you, It likely shows up at 7PM because with the hashrate of your miners your balance first exceeds the threshold at that time. You still receive next-day payment of all the coins you earn up to 12AM Eastern, regardless of when that check mark shows up.
- CritterDog
For me it does not matter if I am over the threshold even hours earlyer.. I will not get the checkmark until exactly 7pm central.. Its not a big deal just want to make sure this is normal.. What is the significance of 7pm? Like now I am at .18 bitcoin way over the threshold but I will not get that black checkmark until exactly 7pm even thiough i am now over it hours earlyer. I was just curious what the significance is of it only checking and giving me the checkmark at 7pm and after..That is the only time it starts checking is 7pm-11pm central.. The way I read your response your saying as soon as I hit thrshold I should get the checkmark and the time should not matter? If this is true then I see this as a bug. Not that its a big deal.. Ok thanksChris Sokolowski wrote:That check mark is generated by the website and doesn't actually mean that the payout is "locked in". Every time you load the page, the website compares your balance to the threshold and shows the check if the balance exceeds the threshold. For you, It likely shows up at 7PM because with the hashrate of your miners your balance first exceeds the threshold at that time. You still receive next-day payment of all the coins you earn up to 12AM Eastern, regardless of when that check mark shows up.
