The moment GPU miners have been waiting for!
A forum to discuss mining pools, features, etc.
This forum is a place to discuss mining pools, features, etc. Topics can include but are not limited to PROHASHING pool.
Contact:
Post by Sarah Manter » Wed Sep 28, 2022 2:34 pm
EthereumPoW (ETHW) is now available at PROHASHING!
ScKryptoguy
Re: The moment GPU miners have been waiting for!
Post by ScKryptoguy » Wed Sep 28, 2022 7:39 pm
I do not see it under worker config or payouts...Real intersted in eth pow too.
Edit:Is it still Ethash
You miss 100% of shots you dont take.....unless you"re a Goalie!!!
thundergun
Post by thundergun » Wed Sep 28, 2022 9:08 pm
Looks like its the same settings as Ethash, but you just have to change to "c=ethereumpow" in the password section.
Heres what is working for me in the Password section:
a=ethash,c=ethereumpow,m=pplns
Just hopped on the ETHW PPLNS Pool, mining smooth, nice to be back to normal overclocks.
Lets find some blocks!
ScKryptoguy
Post by ScKryptoguy » Wed Sep 28, 2022 9:50 pm
Under my worker config its not listed just ethash-low memory.Above that is ethcash
pmzone
Post by pmzone » Wed Sep 28, 2022 10:28 pm
ScKryptoguy wrote: Wed Sep 28, 2022 9:50 pm Under my worker config its not listed just ethash-low memory.Above that is ethcash
it is the same config as the previous ethash. prohashing.com:3339
the c field in the password is not necessary. even the a field is not necessary too.
thundergun
Post by thundergun » Thu Sep 29, 2022 8:19 am
Just switched over a few more rigs. Looks like Eth POW is a bit more profitable that ETChash.
Ill keep a rig on the ETHpow PPLNS Pool for the next few days/weeks if anyone wants to join in on this luck.
Not financial advice, lets find some blocks!
ScKryptoguy
Post by ScKryptoguy » Thu Sep 29, 2022 8:39 am
Now I just have to figure out on how to config Hive os
Contact:
Post by Sarah Manter » Thu Sep 29, 2022 9:11 am
ScKryptoguy wrote: Wed Sep 28, 2022 7:39 pm I do not see it under worker config or payouts...Real intersted in eth pow too.
It's in the worker configurator as Ethash. I'm seeing it in payouts also. Are you seeing it now?
Contact:
Post by Sarah Manter » Thu Sep 29, 2022 9:20 am
ScKryptoguy wrote: Thu Sep 29, 2022 8:39 am Now I just have to figure out on how to config Hive os
Try this:
thundergun
Post by thundergun » Thu Sep 29, 2022 1:33 pm
That worked for Hiveos, mining ETHpow now.
Thank you
