How to deal with Antminer red light flashing?
Come here to chat about mining topics not covered under Mining Pools, Mining Rigs, or Mining Algorithms.
The General Mining Topics forum is a place to discuss topics dealing with mining that don't fall into the categories of our other Mining Forums.
ZEUS MINING
Post by ZEUS MINING » Fri Aug 05, 2022 4:28 am
When your Antminer's fault light is flashing red, you can restore it by restarting.
There are two ways to restart the miner. The first is to turn off the miner, then turn it on again. The second is to click "Reboot" on the miner interface, as shown below:
Miner Backstage> System> Reboot
Of course, there are many possibilities to cause the red light to flash. If it cannot be solved by restarting, you need to repair it according to the inspection results.
rusgal25
Re: How to deal with Antminer red light flashing?
Post by rusgal25 » Fri Sep 23, 2022 4:02 am
sometimes reload the configuration will also help the red light flashing.
Gianna99
Post by Gianna99 » Mon Apr 29, 2024 4:35 pm
It's critical to debug your Antminer as soon as you notice a flashing red light. Make sure the connections and power supply are secure by first inspecting them. Next, check for any problems with the hashing boards, such as loose connections or overheating. For further instructions, see the owner's handbook or look for discussion boards online. Quick intervention can save hardware damage and downtime.GB Whatsapp
lionpurnell
Post by lionpurnell » Thu Jul 18, 2024 4:42 am
So, I've seen the posts of the red light on the face of the surge.
final grade calculator
