config file
bdm8181
config file
Post by bdm8181 » Sun Mar 27, 2022 11:55 pm
im trying to figure out how to update/change the config,json file for xmrig so that my gpu and cpu both mine, if i use the xmrig Config Wizard i get the following
"autosave": true,
"cpu": true,
"opencl": false,
"cuda": true,
"pools": [
"coin": "monero",
"algo": "rx/0",
"url": "prohashing.com:3359",
"user": "bdm8181",
"pass": "n=CryptoBDM",
"tls": false,
"keepalive": true,
"nicehash": false
on the config.json file the section to load cude looks like this
"cuda": {
"enabled": false,
"loader": null,
"nvml": true,
"cn-lite/0": false,
"cn/0": false
other then changing false to true on the enabled line what should i put for the next couple? the "loader" and "nvml" and are the last two lines a coin algor?
thanks
bMeister1
Re: config file
Post by bMeister1 » Mon Mar 28, 2022 1:41 am
Assuming you downloaded the CUDA plugin for XMRig and added the dll files to the same folder as the xmrig.exe executable, all you have to change in the config file is changing "enabled" from false to true and it will handle the rest. Don't expect amazing hashrates though. RandomX was specifically designed to be anti-GPU but given enough power it can almost be like having another CPU core.
Contact:
Re: config file
Post by Sarah Manter » Mon Mar 28, 2022 8:37 am
bdm8181 wrote: Sun Mar 27, 2022 11:55 pm im trying to figure out how to update/change the config,json file for xmrig so that my gpu and cpu both mine, if i use the xmrig Config Wizard i get the following
"autosave": true,
"cpu": true,
"opencl": false,
"cuda": true,
"pools": [
"coin": "monero",
"algo": "rx/0",
"user": "bdm8181",
"tls": false,
"keepalive": true,
"nicehash": false
"cuda": {
"enabled": false,
"loader": null,
"nvml": true,
"cn-lite/0": false,
"cn/0": false
thanks
Is there a reason you're trying to use xmrig for both CPU and GPU rather than using xmrig for CPU and gminer (or another software like that one) for GPU?
