Hello
Please help with this error .
"Share verification failed"
Re: "Share verification failed"
dzieju wrote: ↑Mon Dec 20, 2021 6:05 pm Hello
Please help with this error.
same issue here
Xmrig Version 6.16.2 coin Monero,
4 of my miners has the same issue
worked till 9 am eastern yesterday 12/20/21
used https://xmrig.com/wizard for my config file
"api": {
"worker-id": "deli"
"http": {
"enabled": true,
"host": "127.0.0.1",
"port": 3359,
"access-token": "xxxxx",
"restricted": true
"autosave": true,
"cpu": true,
"opencl": false,
"cuda": false,
"pools": [
"coin": "monero",
"algo": "rx/0",
"url": "stratum+tcp://prohashing.com:3359",
"user": "username",
"pass": "k=xxxx,n=deli",
"tls": false,
"keepalive": true,
"nicehash": false
- Contact:
If you haven't already, can you please put in support tickets so that we can look into this issue?
- Contact:
Where this question has already been posted in this thread, I'm going to remove the duplicate thread.
@dzieju That isnt a support ticket. I know accessing their support is very confusing so i can't blame you, it should be easier to find and they should give direction how to access it when they ask for you to submit because its so hidden.
Post your mining settings as what you have posted will not help anyone solve your problem. My guess tho is your miner isnt setup properly for rx/0
- Contact:
Our support channels are accessible at the top right of the forums screen where it says "Support" through the orange symbols.Estacaco wrote: ↑Tue Dec 21, 2021 12:07 pm @dzieju That isnt a support ticket. I know accessing their support is very confusing so i can't blame you, it should be easier to find and they should give direction how to access it when they ask for you to submit because its so hidden.
I send you email .
My config isnt change and working ok last time .
Now is a problem .
Now is a problem .
I have submitted an email to support as well for this, I noticed that this also started for me yesterday on all 9 of my CPU miners.
try removing stratum+tcp://
