Rejected shares
Muleslayer
Rejected shares
Post by Muleslayer » Sun Sep 02, 2018 11:39 pm
2 Days on my Z9 mini.
Got the following message in “rejected shares”
Equihash solution is using incorrect parameters 150 8.11%
I am connected via port 336 password argument is n=xxxx.
Is this some thing to be concerned about?
Hash rate looks good at 14 to 15.
Muleslayer
Re: Rejected shares
Post by Muleslayer » Sun Sep 02, 2018 11:59 pm
Also as an FYI, a few hours earlier I noticed in “live balance” three payouts in various coins I have used for payouts in the past, having black check marks indicating a payout. 3 hours later the check marks were gone. Balance returned to normal.
Not sure what is happening here.
Re: Rejected shares
Post by CSZiggy » Mon Sep 03, 2018 12:11 am
When a payout coin you requested goes into error mode, you end up getting paid in one of the standards I believe.
So LTC or BTC or ETH or DASH or whatever afaik.
myselfroberthustly
Re: Rejected shares
Post by myselfroberthustly » Wed Sep 26, 2018 10:27 am
I noticed in “live balance” three payouts on various coins I have used for payouts in the past, having black check marks indicating a payout. 3 hours later the check marks were gone. Balance returned to normal. Not sure what is happening here. Thanks and Regards, panda helper emu4ios gbwhatsapp
