System back online
System back online
All services are now back online and everything has returned to normal. The new mining server was successfully installed and the CPU usage never reaches 100% anymore. Ping times are about 90ms lower than they used to be. Chris will process payouts shortly.
Thanks for your patience, and enjoy mining!
localwonder
Re: System back online
System is a bit buggy but live..
Great, thanks for the upgrades!
Steve Sokolowski wrote:All services are now back online and everything has returned to normal. The new mining server was successfully installed and the CPU usage never reaches 100% anymore. Ping times are about 90ms lower than they used to be. Chris will process payouts shortly.
And I was able to recover my account (hotmail email) too!
Go guys, gooooo !!!Steve Sokolowski wrote:All services are now back online and everything has returned to normal. The new mining server was successfully installed and the CPU usage never reaches 100% anymore. Ping times are about 90ms lower than they used to be. Chris will process payouts shortly.
alchemists
You have your ICMP echo turned off, so I cannot check anymore the PING response. Could you ask Chris to turn that back on?
alchemists
Hello Steve,
Can you guys' check. Your network just went down
I alerted Chris of this. I think the problem is that Linux has a default connection limit, and it is just barely getting exceeded on the routing server. New connections can't be established but existing ones function well. This change had been made to the previous router and needs to be made again now.alchemists wrote:Hello Steve,
I told him about it and it shouldn't be difficult to resolve.
alchemists
Thanks Steve,
Please do send an update once completed. Also if you can turn on the echo request on ICMP so we can do a ping test.
Steve good morning!
The problem with the statistics on the rig under CUDA. The hashting is not displayed at all, as if the employee is not online.
