No block reward payout?
tnx
Post by tnx » Mon Jan 15, 2018 2:24 pm
My miner discovered a Cannabis coin block with a 70 reward - my balance has not changed on my payout though? I noticed this with three other recent blocks my miner discovered, can someone please help? This is the URL to the first transaction.
https://prohashing.com/explorer/Cannabiscoin/2656818/
Re: No block reward payout?
Post by AppleMiner » Mon Jan 15, 2018 2:32 pm
Are you in solo mode or PPS mode?
On your LIVE status, click one of the miners and check for MODE:
Unless you are solo mining, you do not gain anything additional for finding block rewards.
If you are NOT using m=solo as part of your password...then you are in PPS mode and will get nothing more for finding blocks.
tnx
Post by tnx » Mon Jan 15, 2018 3:28 pm
AppleMiner wrote:Are you in solo mode or PPS mode?
Thanks that makes sense - I had always assumed the reward was split with the pool. I would do solo but I assume the only thing I'd ever hit is a massive hydro bill with no returns :)
