Mining Adress and diff for Prohash
Hi at all.
So im new here and will test the pool.
have some old Scrypt ( Lightning X6 ) but with the Minera software doesn´t
know wich adress i have tu take.
All Adresses looks like
stratum+tcp://scrypt.eu.nicehash.com:3333
and the Softwate doesn´t take the prohashing.com:3333.
So hope you can help me... And by the way .. Perhaps you can tell me
the best password arguments for the miner.
Thank you so much...
Greetings Dennis
Greetings Dennis
hashingpro
Re: Mining Adress and diff for Prohash
Try using:
But the site has to be up and running at the time.
Use the username for the account you login to check on things, it has to be spelled CASE-SENSITVE when you made the account.
So, Bobbie and BOBBIE are not the same, make sure you spell it exactly with same caps or it wont find your account.
Sorry I dont know much about lightning X6 or what it can do or hash to help with settings after you are conencted.
Good luck
Good luck
micca410evo
Just use the Dmaxl zeus miner, use the stratum like Hashingpro said.
The Dmaxl option fills your line, only correct the chip count and the clock. |edit| Was talking about my thunder x6: [Depending on your system it will probably run good around 200-240 maybe even 280 range. My zeus had the best clock around 243 (only 6-7% of HW errors).]
What Range do you mean with the 280 ?micca410evo wrote:Just use the Dmaxl zeus miner, use the stratum like Hashingpro said.
But at time, become 100% errors...
micca410evo
Clockspeed range.. but like i said, was talking about thunders, try to search the web for optimal machine clocks.. i think it is around 240 for you
Yes.. around 240 is the best clock...micca410evo wrote:Clockspeed range.. but like i said, was talking about thunders, try to search the web for optimal machine clocks.. i think it is around 240 for you
But on this pool, i become 100% errors.
Adress the stratum Username: me Password: Empty
100% errors
micca410evo
Other pools work fine?
Yes.. others work fine.
Minera tells every time Pool status "dead"
This issue with usernames is no longer the case.hashingpro wrote:Try using:
Good luck
Earlier in the week, I announced a change where case-sensitivity was eliminated for usernames. Now, usernames of any case will be accepted.
