Prohashing app for android/IOS
bhuvahh
Re: Prohashing app for android/IOS
Post by bhuvahh » Mon Nov 07, 2022 10:13 am
I am also curious if anyone else has used the API to make an application of their own, so perhaps someone will post here.
weekstonz
Post by weekstonz » Sat Sep 02, 2023 4:54 am
I use this website, works fairly well to display balaces using your API key without having to refresh my phone... You do have to refresh to see up to second hash rate, but balances update automatically with every share submitted...
weekstonz
Post by weekstonz » Mon Oct 30, 2023 4:08 am
People really want to see an app comparable to nicehash that shows you all of the stats and makes it easy.
krnl download
hdstreamz.uno
drokxytext
Post by drokxytext » Fri Jan 19, 2024 7:36 am
I have tried PoolWatch, MiningObserver and Minin Pool Status, none of them seems to pick up on the API.
maazaltaf234
Post by maazaltaf234 » Tue Jan 23, 2024 7:22 am
Vielen Dank für den Hinweis, das hat funktioniert! Wenn ich eine andere Liste ohne Spur auswähle, bleibt der Kartenbereich unverändert. Leider muss man dann in der entsprechenden Liste erneut die richtige Spur suchen und auswählen. Es bleibt also ziemlich umständlich, schade. https://holymolycasinos.net/
jameswookyz
Post by jameswookyz » Thu Feb 15, 2024 5:11 am
waplus
projectfreetv.onl
