Connecting
Connecting
I got most of my .bat set up i believe but i can't figure my head around the passwords. If i put in nothing or empty it tells me it can't connect, if i don't put in ANY password argument it says invalid credentials. What do i do?
Re: Connecting
write n=yourminername in password field
Re: Connecting
Black screen for 20 seconds then "No servers could be used"
Re: Connecting
Pool URL ////////// stratum+tcp://prohashing.com:3333
Username ////////// pilottage
Password ////////// n=my-dearest-L3 d=65536 m=solo c=digibyte
thanks for your hash
Re: Connecting
bfgminer.exe --scrypt -o stratum+tcp://prohashing.com:3333 -u jebbers12 -p "n=miner1d=12345" -d gridseed -S gridseed:all --set-device gridseed:clock=850
pause
Thats what i have written, what do i have wrong?
pause
Re: Connecting
Isn't the pool url just prohashing.com:3333 without the stratum part? That is what I use.
Re: Connecting
no space between n= and d=jebbers12 wrote:bfgminer.exe --scrypt -o stratum+tcp://prohashing.com:3333 -u jebbers12 -p "n=miner1d=12345" -d gridseed -S gridseed:all --set-device gridseed:clock=850
pause
and d= isnt a valid number
Re: Connecting
Greg, is proxy.prohashing.com:443 is up on you? mine is down
