anyone had any luck direct ordering these miners? i have half of a set of these myself. I email inno but .... no response... they are probably flooded... ebay has only marked up pieces remaining and I am hesitant.
I would be interested in joining a group order if any is ongoing i am unaware of.
A4 Dominator Configuration
Re: A4 Dominator Configuration
I directly ordered one on May 12th, got it may 19th. I just placed the order in their form and sent the payment confirmation. On the Tuesday after they confirmed payment receipt and shipped them. They were always a little slow to respond, but they do work quickly. What exactly are you emailing them about?tmopar wrote:anyone had any luck direct ordering these miners? i have half of a set of these myself. I email inno but .... no response... they are probably flooded... ebay has only marked up pieces remaining and I am hesitant.
Pricing on a dominator, i have one a4 module and a controller currently engaged and I was looking to expand.... It has been a few weeks since i emailed them and i figured there were people ordering way more they were paying attention to first which is why i sought a group order for the better rate and more eagerness to fulfill a bigger order.
So I figured out the problem, turns out it was pretty silly, but quite a relief, I have them on the second shelf of a work bench, and it seems I didn't tighten that shelf 100% which caused some vibration which in turn caused one or more data cables to loosen up, so I unplugged and re-plugged all wires and tightened the screws on said shelf, all is working great now!jinxorbit wrote:Image a new SD card and start over, probably quicker than trying to triage the network setup.dj2381 wrote:One of my A4's have stopped communicating, I cannot reach the ip address, anyone experience this before?
Does anyone know what the max safe temp is for these things? Not much info around the net.
link to firm ware 2.10
https://www.nicehash.com/?p=news&id=152
I also have the same problem lol did you figure out how to work the son of a b***** ????dj2381 wrote:Hey guys, I need some help, I just received a pair of these in the mail, all set up and ready to go, power on and IP working, I have this version V1.1.0(TF) if it helps, the lights on the miners are flashing, it says it is running but there is no info to display below or in real time monitoring, it said socket error on the real time monitoring, I am using nicehash, I think I have the correct address set up, can anyone help? Maybe my address is wrong, if someone has the correct nicehash address can you please post it, I could be doing something wrong which is simple to fix, I don't know, any help is welcome.
nivan12345 wrote:I also have the same problem lol did you figure out how to work the son of a b***** ????dj2381 wrote:Hey guys, I need some help, I just received a pair of these in the mail, all set up and ready to go, power on and IP working, I have this version V1.1.0(TF) if it helps, the lights on the miners are flashing, it says it is running but there is no info to display below or in real time monitoring, it said socket error on the real time monitoring, I am using nicehash, I think I have the correct address set up, can anyone help? Maybe my address is wrong, if someone has the correct nicehash address can you please post it, I could be doing something wrong which is simple to fix, I don't know, any help is welcome.
for nice hash
use
in the USA
stratum+tcp://scrypt.usa.nicehash.com:3333 your BTC address for user and PW X
or check here for were you live ...use the scrypt miner address only . !!!! .
https://www.nicehash.com/index.jsp?p=gstarted#seller
if you mine on
prohashing.com
you May want to try this
or
prohashing.com:3333
your log in user as user .
for the Password
with the quotes in the password field .
"d=32768 h=50 g=off n=1" N is the miners name on the Live worker status page it can be 1 to whatever number you want ....
the credit for the Password tweet actually comes form here on the forums and INNOSILICON told me about it.
Do you know what batch the miner is : Batch 1 batch 2 or batch 3 , read this :
https://bitcointalk.org/index.php?topic ... ;topicseen
and try one of these firmware
2.01 https://drive.google.com/file/d/0B-_jcp ... duRFk/view
2.02 https://www.dropbox.com/s/9umhsbtky6t1c ... a.rar?dl=0
if the board has the patch or it is a Batch 3 try these below:
2.03 https://www.dropbox.com/s/sis8eoeo6wxoq ... 3.zip?dl=0
2.10 https://www.dropbox.com/s/at7s9isaraxim ... D.rar?dl=0
Hi guys, i have right now this situation:
The ASC nr. 1 seems to not work because the temp is low. Why this situation? I'm mining in half hashrate.
mine does this once in a while... especially lately for some reason.
Its not broke cuz its cold... its cold cuz its broke. Power it completely off and on after waiting 10 seconds. Hopefully it will come back up online.
I would advise moving it from its current location, I dont think they like vibration at all. I had this piece in the garage up on a shelf by itself for a month and it worked flawlessly. I moved it into a room of other miners and it started having this issue. Because I am running it in an AC'd house i put it on the carpet for the antivibration properties. Lets see how it goes.
