Error in dashboard
Mastermind007
Error in dashboard
Post by Mastermind007 » Tue Sep 21, 2021 11:33 am
I am getting these errors in the dashbound and not sure what I need to do about then.
Mining Monero using RandomX with proswitching.
AUTHORIZATION (60)
6 minutes ago
Authorization failed because there are no coins available to mine for this algorithm.
DISCONNECT (12)
9 minutes ago
The anchor coin is not able to be mined and there are no other suitable coins available for this worker.
DISCONNECT (3)
9 minutes ago
An emergency failsafe was triggered to prevent Prohashing from excessive losses.
Any suggestions?
-MaVerick-
Re: Error in dashboard
Post by -MaVerick- » Tue Sep 21, 2021 11:41 am
Afaik you get a few of them when the mining server restarts for a few seconds, I usually ignore them.
Mastermind007
Post by Mastermind007 » Tue Sep 21, 2021 1:25 pm
-MaVerick- wrote: Tue Sep 21, 2021 11:41 am Afaik you get a few of them when the mining server restarts for a few seconds, I usually ignore them.
Yeah they cleared themselves and miners are working as normal.
Thanks for the reply.
