Goldshell HS5
Leftoverloser
Goldshell HS5
Post by Leftoverloser » Thu Sep 09, 2021 6:08 pm
Just curious if the Goldshell HS5 miner will be supported soon?
Re: Goldshell HS5
Post by Steve Sokolowski » Fri Sep 10, 2021 6:31 am
From what I can tell, this miner mines Siacoin, an algorithm which is not currently high on our priorities list. The next algorithm we plan to support is Chia, and we can't train people quickly enough to be adding multiple algorithms at once yet.
It is possible that we might consider adding Siacoin in the future, after Vance performs a profitability analysis when Chia is done.
berryberry
Re: Goldshell HS5
Post by berryberry » Wed Sep 15, 2021 6:58 pm
I have the small box version of this. The Goldshell HS miners seem to be able to support two algos. blake2b (SC and others) and blake2bsha3 (HNS). Handshake seems to be the only coin using the sha3 variant right now, but there are several coins using the core algo. Here's a screen shot of the algo settings from my miner:
https://i.imgur.com/Y4pJ5B7.png
Info on HNS if you're interested: https://handshake.org
Luke642
Re: Goldshell HS5
Post by Luke642 » Sun Nov 21, 2021 9:54 am
I have the same request.
