Merged Mining question
jreysack
Post by jreysack » Sun Jul 04, 2021 10:41 pm
I am solo mining litecoin, and im getting Myriadcoin
AdvancedInternetBlock & Dogecoin it shows, but then it's all converted to Litecoin.. why am i not earning dogecoin as dogecoin? along with the others as those separate coins?
Alynn
Re: Merged Mining question
Post by Alynn » Sun Jul 04, 2021 11:32 pm
all merge mining is paid as per share in the primary mined coin.
jreysack
Post by jreysack » Mon Jul 05, 2021 10:00 am
that doesn't answer the "why" though. Id rather earn the litecoin as the litecoin and the doge as doge.
Post by Steve Sokolowski » Mon Jul 05, 2021 4:58 pm
jreysack wrote: Mon Jul 05, 2021 10:00 am that doesn't answer the "why" though. Id rather earn the litecoin as the litecoin and the doge as doge.
There isn't a particular reason why - it was just the first method of payouts that was implemented. Something had to be done first.
If you'd like, I can add this suggestion to the feature requests.
jreysack
Post by jreysack » Mon Jul 05, 2021 5:46 pm
Please do! Also with a person solo mining, for example mining litecoin, and the byproduct being doge. With the block rewards of 10k doge, shouldnt that be going to the person that mined it, seeing as they're the ones that are associated with the block? I can see being pps for the litecoins etc.
Philipdz
Post by Philipdz » Tue Jul 13, 2021 6:39 am
Steve Sokolowski wrote: Mon Jul 05, 2021 4:58 pm
Please do! I would like to solo mine LTC and Doge as well.
Question. if someone Solo mines a Doge block while mining LTC does the entire DOGE block get converted to LTC as payment under the current payout settings for solo mining?
Post by Steve Sokolowski » Tue Jul 13, 2021 12:33 pm
Philipdz wrote: Tue Jul 13, 2021 6:39 am
In solo mining, merge-mined coins are paid per share, regardless of whether the customer finds primary coin blocks or not. That's why solo mining customers see a small but steady increase in earnings at all times, and then a large increase when a primary block is found.
