Gminer does not install
Ltd123
Post by Ltd123 » Wed May 12, 2021 7:29 pm
Please help, I downloaded zip file for 2.52 version, click on miner.exe and it just flashed and that's it. Nothing open or install. I tried edit the mine_eth.bat file then click on that. It just open but did not run. Not sure what else to do.
-MaVerick-
Re: Gminer does not install
Post by -MaVerick- » Wed May 12, 2021 7:32 pm
https://prohashing.com/guides/gpu-quick-start should give you a good starting point. There is no installer, only .bats and commands.
Ltd123
Post by Ltd123 » Wed May 12, 2021 7:40 pm
Thank you, I'll look
