Proswitching question
Jaiven
Post by Jaiven » Sun May 09, 2021 11:04 pm
Hello, I am a bit confused with Proswitching and tried looking in the forums but didn't find a clear answer. I saw in a previous post someone stated Gminer is for ethash and equihash variant coins. So of I have c= omitted from mine_eth.bit does Proswitching enabled mine the eth and variant coins only? I ask because on the documentation page it is vague enough to make it sound like it switches to any coin which from what I was reading about these different algorithms would be bad based on your setup and what miner you are running. I'm just trying to make sure I am using Proswitching properly and to its full potential.
TLDR: I don't have "c=" in mine_eth.bat and only use=[worker name] like the tutorial tells me to. Am I doing it right for Proswitching?
Alynn
Re: Proswitching question
Post by Alynn » Mon May 10, 2021 7:09 am
Proswitching doesn't change algorithms. So if you are setup for equihash you can swap between whatever equihash. Ethash only has one coin, so it's just that coin.
--algo ethash --pers auto --server prohashing.com:3339 --user username --pass n=[Worker-Name],l=[RAM in GB]
this should be the minimum you need for ethash. Note you don't HAVE to set l, but for ethash it is better that you do.
Jaiven
Post by Jaiven » Mon May 10, 2021 7:47 am
Thank you Alynn,
What is the --pers auto command?
Alynn
Post by Alynn » Mon May 10, 2021 7:53 am
Sorry I should have removed that. It hurts nothing but is actually for equihash
Jaiven
Post by Jaiven » Mon May 10, 2021 4:27 pm
No worries and thank you for the help.
