UFO/Neoscrypt issue with JSON
Alynn
Post by Alynn » Fri Mar 19, 2021 3:06 pm
Is there an issue with UFO PPLNS?
I found a block about 20 minutes ago but now both my miners are reporting that JSON-RPC call is failing, and they keep trying to connect.
I am able to connect using the proxy but still unable to get the json file. So it looks like we have an error on 3338.
Quick edit, the same is true for PPS and Solo.
