Block explorer webpage fix.
Post by CSZiggy » Wed Nov 21, 2018 4:28 pm
I was looking over some of the found blocks on the block explorer.
Seems like that code was for when the pool was just scrypt, and then the code got copied to all the other algos.
As a result, "How to mine" line directs all algos to the port 3333.
Could Constance change the block explorer's webpage output to match the port of the algo the coin was found on.
Either add the a= setting into the line or just change the port so the "HOW TO MINE" line works for algos other than scrypt.
Thanks.
