want to withdraw
leskgr
want to withdraw
Post by leskgr » Mon Nov 12, 2018 5:41 pm
my Litecoinsa to nicehash. Please help. thanks in advance!
Re: want to withdraw
Post by CSZiggy » Mon Nov 12, 2018 6:59 pm
Since NiceHash only works in BTC, I am not sure how you are going to do that.
You will most likely need to send them to an exchange(free from prohashing if over auto withdrawl limit)
Then exchange LTC to BTC at the exchange, paying whatever fees they require.
Then send the converted BTC over to nicehash...again paying whatever transaction fees to send the BTC over to NiceHash.
Going forward, you could choose to get paid in BTC on Prohashing site and send those to Nicehash, but you have to get the BTC auto-pay limit to get a free send, or it will cost if you ask for it early. Check the minimum price-payout required before you swap to BTC, it may take a while depending on your hashrates/frequency of using the pool.
There is no way on the site to convert from 1 coin to another. Pool managers claim they need money license - which I don't get as we never work with money on here....according to the US tax code, we only work with real estate property. If anything I would ask why all mining pools don't have a real estate license instead in order to handle all this real estate we make with our miners.
Rakly3
Post by Rakly3 » Sun Nov 25, 2018 7:24 am
How do I request a withdraw?
ajs
Post by ajs » Sun Nov 25, 2018 10:39 am
Rakly3 wrote:How do I request a withdraw?
On the "Settings" page, under Payout Addresses, set the "Your Threshold" amount to the minimum. It will trigger in the next 12 hours or so.
Rakly3
Post by Rakly3 » Sun Nov 25, 2018 11:01 am
oh, ok.
Thanks!
