Nicehash is connected to the X11 of the prohashing mine, and the mine is nearing death.
o51888
Post by o51888 » Sat Aug 04, 2018 10:13 pm
Nicehash is connected to the X11 of the prohashing mining pool. Various parameter settings have been tested. There have been a lot of rejections, 50%~100% rejection rate, and the mine pool is close to death. It has been many days in a row! Please resolve as soon as possible.
Re: Nicehash is connected to the X11 of the prohashing mine, and the mine is nearing death.
Post by CSZiggy » Sun Aug 05, 2018 12:30 am
Did you use port 3333 and a=x11 or did you use the x11 specific port when you were connecting and testing?
Did you take any screen shots of the 50-100% rejected rates? Maybe some pictures might help the owners look into the issue?
Were using autopool or did you try solo mining or static mining a single coin all day?
I would think if there was a far reaching issue a lot more X-11 users of nicehash might have said something by now.
lacik
Post by lacik » Sun Aug 05, 2018 7:21 pm
Im stopped nicehash mining on Prohashing due same problems. High rejection rate even with using port 3334 an x as password. Im wrote this several times there, no solusion, as I see.
o51888
Post by o51888 » Sun Aug 05, 2018 9:58 pm
port 3333 and a=x11
port 3334 and a=x11
port 3333 and a=x11 and g=off
port 3333 and a=x11 and g=off and h=50
All the above parameters have been tried, and the rejection rate is 50%~90%.
Post by CSZiggy » Mon Aug 06, 2018 12:40 am
port 3334 and no password at all?
