any recommendation with password arguments and L3+
kevbeam
Post by kevbeam » Mon Mar 26, 2018 10:46 pm
i dont quite understand the password arguments so could someone tell me what should be the best for my antminer L3+
CritterDog
Re: any recommendation with password arguments and L3+
Post by CritterDog » Mon Mar 26, 2018 11:13 pm
kevbeam wrote:i dont quite understand the password arguments so could someone tell me what should be the best for my antminer L3+
I use
d=65536
kevbeam
Post by kevbeam » Mon Mar 26, 2018 11:16 pm
does it seem to do well
Aura89
Post by Aura89 » Tue Mar 27, 2018 12:11 am
Don't use anything other then potentially naming your L3+, the best results will be from no password arguments unless you are planning on solo mining
Post by CSZiggy » Tue Mar 27, 2018 12:19 am
I would use the lowest difficulty setting the pool will allow.
No difficulty setting will result in a calculated difficulty being applied that only yields 1 share per minute.
