$108 for a found block
RBTData
Post by RBTData » Sat Jan 06, 2018 6:43 pm
https://gyazo.com/74e9c70f5f1783d37207feabcb062c0f
how can i check to see if ive been paid for this block?
suhalleyiv
Re: $108 for a found block
Post by suhalleyiv » Sat Jan 06, 2018 7:02 pm
Well do you have c=Digibyte m=solo in your password field?
3Moose
Post by 3Moose » Sat Jan 06, 2018 7:46 pm
you only get paid that amount IF you solo mine. PPS miners (the default) do not get that payments. Its pooled. I find 30-50+ blocks a day.
RBTData
Post by RBTData » Sat Jan 06, 2018 8:40 pm
doh, no not solo mining, thought it was too good to be true.
RBTData
Post by RBTData » Sat Jan 06, 2018 9:05 pm
ive just put this in my password and still hasnt found valid shares
p=.27 w=1300 c=Digibyte m=solo with prohashing.com:3333#xnsub in url
Post by AppleMiner » Sat Jan 06, 2018 9:30 pm
#xnsub is not needed.
And for digibyte depending on your hashrate, it may take days to find a block, if ever.
All depends on luck and how much hash you have.
RBTData
Post by RBTData » Sat Jan 06, 2018 9:40 pm
all setup up now, 3 x d3 solo cannabiscoin and 1 x L3 solo digibyte, see how i go for a week or so. when mining in a pool and i see i found a block and it paid .016, does that cent get split between the pool or do i get the whole cent? seems useless splitting it with the pool
Post by AppleMiner » Sat Jan 06, 2018 9:53 pm
always in the pool it gets split. if you are solo you get to keep that .016
so if you mine for 3 days and find one...instead of making $18 - $25 a day on a L3+...you made .016
RBTData
Post by RBTData » Sat Jan 06, 2018 10:23 pm
wow, better off in pool, even if you solo and find blocks. i think im better off going back to the pool
