Advanced Internet Block AIB
seovit
Contact:
Post by seovit » Sat Dec 23, 2017 3:53 am
what parameterts must i place in password for solo mining Advanced Internet Block Coin AIB ??
greaseman316
Re: Advanced Internet Block AIB
Post by greaseman316 » Sat Dec 23, 2017 4:52 am
refer to your other post
Post by AppleMiner » Tue Dec 26, 2017 4:54 am
seovit wrote:what parameterts must i place in password for solo mining Advanced Internet Block Coin AIB ??
Good luck, that coin drops off the network after every 5th coin gets found, and typically takes my miners mining it offline for the next 30 mins before they can connect in again.
Also even if you find AIB, there is like 40% + chance it will go orphaned.
Good luck with that.
