Live balances - payout eligible stays zero
BitOfaCollector
Post by BitOfaCollector » Sat Dec 02, 2017 5:29 pm
I've got a D3 actively running and set with a=X11. I have my settings to payout to lightcoins and I got payouts.
But somehow the Live balances section shows permanent "Payout eligible: 0.00000000".
Is normal behavior due to transfering X11 coins to litecoins?
skinner
Re: Live balances - payout eligible stays zero
Post by skinner » Sat Dec 02, 2017 5:36 pm
no this is not normal, looks like there is a bug.
I havnt changed any settings and my eligible payout is 0.0000000 as well.
currently have 0.077 and payout is set to 0.1 which i will reach in about 3 hours.
Post by AppleMiner » Sat Dec 02, 2017 9:05 pm
Check back at midnight, see if you are still 0.00000 payout eligible.
BitOfaCollector
Post by BitOfaCollector » Sun Dec 03, 2017 4:21 am
Yes ... it is filled again. So all is Ok.
Thanks for the quick action.
Regards,
Maarten
