Minera Gridseed G-Blade and Zeus Hurricane
BLincs
Post by BLincs » Fri Nov 10, 2017 2:04 am
I'm having issues with Minera on my Raspberry Pi 2 using my G-Blade and Zeus Hurricane. ( yeah I know they are older asic miners but my brother passed them down to me when he got his new hardware I have another zeus hurricane but I'm waiting on another psu to use it) I'm having issues on PH where my miner disconnects from the pool completely as if the pool is dead every time the pool finds a new block. I don't have this issue when I was mining on my windows rig.
my config:
--scrypt --scan-serial gridseed:auto --gridseed-options freq=825,chips=40 --scan-serial zeus:auto --zeus-chips 64 --zeus-clock 330
JSON file being loaded:
    "api-listen": true,
    "api-allow": "W:127.0.0.1",
    "log-file": "\/var\/log\/minera\/cgminerdmaxlzeus.log",
    "pools": [
            "url": "stratum+tcp:\/\/prohashing.com:3333",
            "user": "BLincs",
            "pass": "n=tmdGZ"
CONSOLE log:
 [2017-11-10 06:43:04] Started cgminer 4.3.5-scrypt.2
 [2017-11-10 06:43:04] Loaded configuration file /var/www/minera/conf/miner_conf.json
 [2017-11-10 06:43:04] GridSeed options: 'freq=825,chips=40'
 [2017-11-10 06:43:04] Gridseed device found, firmware v02140317, driver v3.8.5.20140210.02, ID ttyACM0
 [2017-11-10 06:43:04] GSD0: System reseting
 [2017-11-10 06:43:04] GSD0: Set GC3355 core frequency to 825 MHz
 [2017-11-10 06:43:04] Gridseed device found, firmware v02140317, driver v3.8.5.20140210.02, ID ttyACM1
 [2017-11-10 06:43:04] GSD1: System reseting
 [2017-11-10 06:43:05] GSD1: Set GC3355 core frequency to 825 MHz
 [2017-11-10 06:43:07] Found Zeus at /dev/ttyUSB0, mark as 0
 [2017-11-10 06:43:07] GridSeed GSD0 opened on usb:/dev/ttyACM0
 [2017-11-10 06:43:07] GridSeed GSD1 opened on usb:/dev/ttyACM1
 [2017-11-10 06:43:07] ZUS0 opened on /dev/ttyUSB0
 [2017-11-10 06:43:07] Probing for an alive pool
 [2017-11-10 06:43:17] Waiting for work to be available from pools.
 [2017-11-10 06:43:37] Pool 0 difficulty changed to 65536
 [2017-11-10 06:43:38] Network diff set to 1.01M
 [2017-11-10 06:43:38] Work available from pools, resuming.
 [2017-11-10 06:43:43] API running in IP access mode on port 4028 (13)
 [2017-11-10 06:43:43] GridSeed options: 'freq=825,chips=40'
 [2017-11-10 06:43:52] GridSeed options: 'freq=825,chips=40'
 [2017-11-10 06:44:37] GridSeed options: 'freq=825,chips=40'
 [2017-11-10 06:45:40] Stratum from pool 0 detected new block
 [2017-11-10 06:47:36] Stratum from pool 0 detected new block
 [2017-11-10 06:48:55] Accepted 9d6416b1 Diff 107K/65536 GSD 1
 [2017-11-10 06:48:59] Network diff set to 1.03M
 [2017-11-10 06:48:59] Stratum from pool 0 detected new block
 [2017-11-10 06:49:19] GridSeed options: 'freq=825,chips=40'
 [2017-11-10 06:49:34] Network diff set to 44
 [2017-11-10 06:49:34] Stratum from pool 0 detected new block
 [2017-11-10 06:49:45] Pool 0 difficulty changed to 32768
 [2017-11-10 06:49:45] Stratum from pool 0 requested work restart
 [2017-11-10 06:50:00] Accepted 4ef38b88 Diff 212K/32768 ZUS 0
 [2017-11-10 06:50:22] Network diff set to 633K
 [2017-11-10 06:50:22] Stratum from pool 0 detected new block
 [2017-11-10 06:51:02] GridSeed options: 'freq=825,chips=40'
 [2017-11-10 06:52:03] Network diff set to 12.4K
 [2017-11-10 06:52:03] Stratum from pool 0 detected new block
 [2017-11-10 06:52:07] Accepted 611e08df Diff 173K/32768 ZUS 0
 [2017-11-10 06:52:20] Network diff set to 715K
 [2017-11-10 06:52:20] Stratum from pool 0 detected new block
 [2017-11-10 06:52:33] Network diff set to 638K
 [2017-11-10 06:52:33] Stratum from pool 0 detected new block
 [2017-11-10 06:52:52] GridSeed options: 'freq=825,chips=40'
 [2017-11-10 06:53:21] Pool 0 difficulty changed to 16384
 [2017-11-10 06:53:21] Network diff set to 708K
 [2017-11-10 06:53:21] Stratum from pool 0 detected new block
 [2017-11-10 06:53:39] GridSeed options: 'freq=825,chips=40'
 [2017-11-10 06:54:03] Accepted ac1c15d4 Diff 97.5K/16384 ZUS 0
 [2017-11-10 06:54:20] Network diff set to 806K
 [2017-11-10 06:54:20] Stratum from pool 0 detected new block
 [2017-11-10 06:54:23] GridSeed options: 'freq=825,chips=40'
 [2017-11-10 06:54:41] Accepted 017c1ff0 Diff 44.1K/16384 ZUS 0
 [2017-11-10 06:56:02] Pool 0 difficulty changed to 8192
 [2017-11-10 06:56:02] Network diff set to 812K
 [2017-11-10 06:56:02] Stratum from pool 0 detected new block
 [2017-11-10 06:56:22] Stratum from pool 0 detected new block
 [2017-11-10 06:56:43] Accepted 041b2a0d Diff 16K/8192 GSD 1
 [2017-11-10 06:56:44] Accepted 05595783 Diff 12.3K/8192 ZUS 0
 [2017-11-10 06:56:49] GridSeed options: 'freq=825,chips=40'
 [2017-11-10 06:57:00] Accepted 04144f2f Diff 16.1K/8192 GSD 0
 [2017-11-10 06:57:00] GridSeed options: 'freq=825,chips=40'
 [2017-11-10 06:57:36] Accepted 049441b9 Diff 14.3K/8192 GSD 1
 [2017-11-10 06:57:37] Accepted 060fd486 Diff 10.8K/8192 ZUS 0
 [2017-11-10 06:57:42] GridSeed options: 'freq=825,chips=40'
 [2017-11-10 06:57:52] Accepted 7dc22be8 Diff 133K/8192 ZUS 0
 [2017-11-10 06:57:57] Accepted 03d83b39 Diff 17K/8192 ZUS 0
 [2017-11-10 06:58:15] Accepted 5bc0911b Diff 183K/8192 GSD 1
 [2017-11-10 06:59:37] Probing for an alive pool
 [2017-11-10 06:59:37] Testing pool stratum+tcp://prohashing.com:3333
 [2017-11-10 06:59:46] Stratum connect failed to pool 0: Connection timed out after 30001 milliseconds
 [2017-11-10 06:59:47] No servers were found that could be used to get work from.
 [2017-11-10 06:59:47] Please check the details from the list below of the servers you have input
 [2017-11-10 06:59:47] Most likely you have input the wrong URL, forgotten to add a port, or have not set up workers
 [2017-11-10 06:59:47] Pool: 0  URL: stratum+tcp://prohashing.com:3333  User: BLincs  Password: "n=tmdGZ"
This happens at about the same time every time I run my miners on minera ... I'm at a loss.
ZiGen
Re: Minera Gridseed G-Blade and Zeus Hurricane
Post by ZiGen » Fri Nov 10, 2017 2:06 am
Just use Windoze than... :lol:
BLincs
Post by BLincs » Fri Nov 10, 2017 2:10 am
ZiGen wrote:Just use Windoze than... :lol:
the windows rig was just a temp setup as it is my main computer and is used for work not to mention my office runs hot so I needed to relocate the miners to a cooler part of the home. hence the pi setup
ZiGen
Post by ZiGen » Fri Nov 10, 2017 2:38 am
Have to look back in my computers to find some old setup/config for the Blades...Also if I remember properly Zeus miners use a different DRIVER(S) for the rs232 interface than the Greedseeds ...
djliss
Post by djliss » Fri Nov 10, 2017 5:32 am
for the gridseeds this seems to be pretty stable Gridseed blades and minera
see pic here
https://i.imgur.com/MiIQdMp.png
martian
Post by martian » Fri Nov 10, 2017 6:49 am
My gridseeds was stored in the closet for a while I was hit by the cryptsy crap. Returned my pi had the old 6.1 image and it was working perfectly fine. Then I updated to 8.1 and have flashed it and other things several times and cannot even get minera to read my gridseeds at all. It's an issue with minera I know it is he won't admit it and I have tried rebuilding the miner and other things still doesn't work. So I have an old p4 PC running cgminer and it works fine as long as you replace the driver with zidiag or whatever it's called.
djliss
Post by djliss » Fri Nov 10, 2017 8:00 am
yeah i had issues with 8.1 at first but config i'm running seems to be good now, had to reset the stats a few times to get it sorted and had a few issues with SD cards with not starting properly, wrote it to the noobs card i had in the end and haven't had any issues since.
this is my json config using cpuminer
Miner will start with this syntax:
/usr/bin/screen -dmS cpuminer /var/www/minera/minera-bin/minerd --gc3355-detect --freq=838 --gc3355-chips=40 -c /var/www/minera/conf/miner_conf.json
JSON Conf:
"log": "\/var\/log\/minera\/cpuminer.log",
"pools": [
"user": "djliss",
"pass": "d=8192 n=griddir"
"url": "stratum+tcp:\/\/litecoinpool.org:3333",
"user": "djliss.1",
"pass": "1"
"url": "stratum+tcp:\/\/eu-01.miningrigrentals.com:3333\/#skipcbcheck#xnsub",
"user": "djliss.47564",
"pass": "gridseed"
